- opnspacesNavigator II
If there is no documentation on in the coach you might try holidayrambler.com
On tat website they have a change of ownership section that gives a support phone number that might be of help. Change of ownership link
- nickthehunterNomad III
You can buy gas struts on Amazon or many automotive stores. They are sold by length and “force” rating. The length should be pretty simple. The force is probably stamped on the original, if not, it is simply the weight of the awning divided by 2 (assuming you have two struts holding the awning up). The force can be more or less if the strut is mounted in an unusual position so it is best to get the rating off the original. If that is not possible, google gas struts and there is a plethora of information on the force rating and how to determine it.
