mielock's avatar
mielock
LED strip lighting with automatic door switch
It hit me one day that since the LED lighting operates with 12 VDC, adding a simple micro-switch to the door would eliminate the need for a wall switch. So I picked up the micro-switches from Radio Shack for $3.49/each and tapped an always nearby 12 VDC source, and now I have lights that turn on/off as the door opens/closes. If you look closely, you can see the switches mounted at the top side, with all wiring tucked neatly away never to be seen.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Jan 08, 2023
