craz_z
Feb 29, 2020Explorer
ScottG wrote:
So you could drop any BMS equiped LI battery into a common, converter charger designed system for standard wet-cell batteries and it would do fine on its own?
With a drop in lead acid replacement lifep04 battery the short answer is yes the bms will take care of the rest.
Ideally solar is the best way and only turn on the converter as needed.
With any solar charger that is programmed to not absorb or float and cut-off at 14.4 ideally 13.7 I see NO advantage whatsoever in investing in a lithium specific charger.
Without solar I would not just leave the converter on 24/7 plugged in 365 days a year. then i would consider a lithium charger but if your a rv park person lithium was kind of a waste of money.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,354 PostsLatest Activity: Mar 15, 2025
