TC_Z's avatar
TC_Z
Need Coax for Roof Antenna
Hi, a tree branch caught the loop of coax at the base of my crank up antenna and ripped it apart. I need to cut, strip and crimp a connector on the stub that remains. Then I need a 4-5 ft length of coax with connectors to run up the lift arm to the antenna and a bullet to join them together. Where can I buy these items that are high quality and weather proof? Original was just RG-59. I want to upgrade to outdoor rated cable. Outdoor rated connectors with o-rings, etc. Not just the normal indoor bubble pack at Lowes. Moisture is what kills the TV signal.
Thanks....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
