Weldon
Sep 24, 2014Explorer
I would use duct tape on seams and screw heads. Your luan should be the same thickness as the old where it meets the ends. Did your old epdm go under the front and back ends? If yes then the thickness of luan needs to be the same in order to get the new epdm under the ends.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
