โMay-09-2012 07:11 PM
โApr-03-2017 06:56 PM
โApr-03-2017 06:52 AM
โMar-20-2017 09:07 AM
โMar-20-2017 05:47 AM
jolooote wrote:
This is all well & good BUT ... Please read my initial post. I have the newer style FLUSH mount windows. They don't have a outside frame.
โMar-19-2017 06:04 PM
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
โSep-01-2016 04:11 PM
โMay-27-2015 07:46 PM
โMay-17-2015 11:58 AM
Nuke-E wrote:
I really like this idea--here's my question: What would prevent someone from using a regular RV window in the door? Is there something special about it other than size? Right now I don't have a window in the door at all (though I have one of the cheap windows that was given to me laying around), so size really doesn't matter. Thoughts?
โMay-17-2015 03:12 AM
โMay-16-2015 11:38 PM
โJan-30-2015 04:56 AM
Most all doors are the same,if your plastic frame is that size then it will fit.If you will look at the Install pictures in the first post you will see that the hole is of the size needed for the window.
Not only have I installed mine,I'm the OP, I have helped on a few others and have had no problem at all.
โJan-29-2015 05:35 PM
Hunter11 wrote:
For those that have installed this window I am assuming most all door windows are a standard size. I emailed Sue about the window fitment and she said "The window will fit if the hole size is 15 x 24". I am seeing most standard window openings showing 12 X 21. The plastic window frame around ours right now measures 15 X 24 so by her email I am unsure it will fit our window opening. I would think since it fits most others on here it would fit ours but don't want to order it and find out it won't.
โJan-27-2015 05:12 AM
โJan-27-2015 03:35 AM
