horton333's avatar
horton333
No Insulation in Enclosed Bottom
Hi,
So working on a wiring issue that required removing a service plate I was a bit surprised to find there is no insulation under the plastized cardboard that encloses the tanks and the bottom of the trailer, at least not back as far as the water tank. They have taken some care to seal out air, with foam sealing to the frame and where stuff cuts through, I take it the theory is just blast a lot of hot air in, forget efficiency.
Is no insulation normal, or is mine just cheap, or do they come in various levels of insulation?
Comments please?
Tracer Air 238.
