STBRetired
Jul 06, 2020Explorer
Look at the way the existing valve set is installed. The water connections are horizontal, not vertical as would be needed for the faucet you chose. You would have to drill new holes in the "box" and plug the old ones somehow. Hopefully there is enough extra PEX behind the box to reach the new mounting position, or you will need to extend them. I think putting a dish sprayer head on the end of the hose instead of the shower head is the best suggestion.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
