SCVJeff
May 28, 2016Explorer
Never heard of anyone not happy with the head but he has valid points on water usage and especially the hose. I replaced the hose with a 6' ultra flexable hose with a stainless outer jacket and was so impressed, did the outside shower as well as the home showers. Check out Home Depot
I also did a bucket test and found the oxygenics uses as much water as the stock ITASCA head, but if you simply install a shutoff valve and back it off, the savings goes WAY up, and frankly it's a better shower with reduced flow. I sure wouldn't give it up
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 23, 2025
