Painting the Walls of the 5er
jodeb720
My wife convinced me last summer to paint the inside of the trailer.
As I've read multiple times the process is as follows:
1. Lightly sand the walls with electric sander - mechanical adhesion.
2. Wipe down the walls with water
3. Wipe down the walls with TSP
4. Rinse walls - removing the TSP.
5. Prime & Paint.
Tried and true.
This morning I was told that the sanding was never done, and when she was pulling back the painters tape, it was peeling off.
I'm at a cross roads.
She wants to put up wall paper on two of the walls - which will stick to the paint.
My question is this:
Will the freeze/thaw and movement of the walls cause the paint to peel and I'll be redoing this in 6 months or do I need to sand off the paint, and then reprime/paint the walls?
Thoughts?
Thanks
Josh
11 REPLIES 11
frankwp
riven1950 wrote:
Imo skip the sanding. Use oil-based kilz. It stinks but will stick to anything and anything will stick to it.
Ventilation!!!
Kilz is great stuff, but it won't stick to the silicone compound used in the polish they wipe down the wood & sometimes the wall paper with. It's great at hiding scuffs and abrasions, but no paint will stick to it. If it's thoroughly washed off with naptha, then sanding is not needed.
Zinsser BIN primer is also very good at sticking to almost anything.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
riven1950
Ventilation!!!
Flyfisherman128
Do it right and do it once. The paint is your base for the wallpaper.
I wouldn't apply wallpaper over paint that does not adhere to the wall.
Ditto
Veebyes
As a cleaning product naptha is a seldom mentioned but very effective product for removing anything on the surface before it. Lacquer thinners or Acetone work well too.
2007 Alpenlite 34RLR
C_Schomer
^^^ thatโ€™s what I was thinking.โ€ฆ Some sort of industrial coating, not found in the average paint department. The painters at work tell me some of these industrial coatings, primers??, Will stick to darn near anything. Including galvanized sheet metal that is not yet weathered. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
jjrbus
Unless I am missing something I find the sanding confusing. The interior walls in the bulk of RV's is vinyl. I see no reason to sand vinyl???
Prep is super important, TSP would be my first choice. I would double rinse.
Then prime with an alkyd primer, such as Benjamin Moore, Sherwin Williams, nothing from the big box stores.
My opinion and worth what you are paying for it.
frankwp
We got so tired of the dark everything in our 2011 fifth wheel & painted everything, including "wood work" a couple of years ago. Replaced all the flooring with LVP, and installed a new bamboo counter with an undermount SS sink.
What a lot of work that was, but so worth it! Now it's light, bright & more contemporary looking. I'm sure you'll enjoy your "new" trailer.
2010 Cruiser CF30QB
jodeb720
we wiped down the walls first with soapy water
Then we wiped down the walls with TSP -
and then she painted it.
Then I got involved, and we sanded all the walls - pulling most of the paint out - but there were places I could peel the paint off.
wiped htem down again, two coats of paint and now... sigh, wallpaper.
happy wife happy life.
At least the paint & wall paper won't fall off!!!
frankwp
RV manufacturers seem to just love slathering some sort of furniture polish containing silicone oil everywhere inside the RV. Silicone is probably one of the best release substances there is and it is very difficult to remove all traces of it. Even sanding doesn't get it all. The surface needs to be washed thoroughly with naptha or lacquer thinner first.
2010 Cruiser CF30QB
jodeb720
Gbopp - Thanks so much for confirming my suspicion.
I went back to the trailer today, and was able to sand the walls - with some 60 grit to pull the paint off and then rough up the walls.
What shocked my wife was when I took a scraper blade, and just pushed it up the wall, and the paint peeled off like it was held on with a static charge.
She was shocked.
So, after a few hours of sanding, and elbow grease, and more hand sanding and scraping, it's all roughed up, repainted, windows and doors cut in, and ready for wallpaper.
thanks so much for the prompt reply!
josh
gbopp
