scottyboy28422's avatar
Sep 05, 2014
Question about the water pump?
Thanks for all the info on the 110 v fridge use. looks like we need a solar panel and an inverter. Built my own 12 ft RV and got lots of nice parts from a 2011 Zinger. Got this white flexible hose that teed in to water flow. forgot to make a note of it when removing . where does it connect to?
[img][/img]
  • Still haven't got the picture posting correct.
    As suggested in your other post.......white flexible tubing teed into water could be a 'winterizing kit'. Teed into suction side of pump, stick it in a bottle of RV anti-freeze and then pump it thru lines.
    Otherwise......if teed into pressure side of plumbing, could be a feed to a faucet, goes to city water connection , ??????
    Really hard to tell without a picture OR a good description of where that line tees into plumbing system
    ON EDIT:
    Here is a link to your other post with a picture and answer (thanks to bshpilot).........LINK
    It is a winterizing kit.
  • You asked the same thing yesterday and it was answered, did you forget you asked already?
About DIY Maintenance
