eddd's avatar
eddd
Remodeled to get a real bed.
I have a 26' 2002 KZ Sportsman pull behind toy hauler that I use alone 99% of the time.. This model has a 10' enclosed garage and 16' of living area. I looked long and hard to find a smaller pull behind with an enclosed garage. When you have specific requirements in one area, you are likely to have to make compromises in other areas. My compromise was not having a real bed. The front had a U-shaped sitting/dining area that could be made into a bed by folding the table legs and using that along with a the cushions around the U to make a bed of sorts. I only tried that once. It was way more effort than it was worth. That left the couch. It flipped down to make a bed, but not a great one by any means. Even worse, the propane heater is located under the couch and directly beneath your head when you are in bed.
The table had to be a certain size so it could be used as part of the bed, and the folding legs were less than ideal.
I wanted a real bed, that I did not have to make up each night and one where the sheets and blankets didn't constantly slide off. A little more usable room would be welcome as well. This had me looking at different trailers, and even considering a fifth wheel, something I wanted to avoid if at all possible so I could retain full use of by truck's bed. I stood in my trailer many times trying to figure how I might reconfigure it to give me a regular bed.
I failed to take a picture of my own but here is a link to what things looked like before I started:
Linky
And the after:
I searched for something to use for my table top and found a guy who had a large dining table with bad legs for $20. This was perfect since I only need the top. I cut a 32"x30" section out of the top, sanded and finished it. It is a full inch thick butcher block and looks great.
I had to cut down the foam for the cushions and reduce the size of the cushion covers which involved lots of hand sewing. I used the left over material to decorated the area around the bed to give it a more finished look. I also took the opportunity to add a layer of insulation board under the bed and seats.
I also removed the privacy curtain and pretty much eliminated a small section of wall that was meant to separate the two sleeping areas, but really just took up space and make the area feel cramped. The removable table posts finished off the project.
  • DennisG9 wrote:
    eddd,
    Might try some of that foil covered bubble wrap under your matres to cut down on the radiant cold that seep up from underneath.
    I did add a layer of foil-faced insulation board under the bed and sitting areas. I also bought a heated mattress pad, one with the best reviews I could find. The heated pad puts the heat where it can do the most good, and with a nice oscillating electric ceramic heater I don't have to use the trailer's noisy propane heater.
  • eddd,
  • I got a bonus in all the wood left over from the table top. The table was a butterfly leaf type so I have the four leaf sections as well as the table ends that are each the size of large drop leaf.
  • I love seeing this type of reno.
    great job. I will definitely steal your repurposed table idea for my Dinette project!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
