Dutch_12078
Aug 12, 2017Explorer II
If this is a permanent removal, after the floor flange is removed, use a wood rasp or tilt base jig saw to bevel the opening to about a 45 degree angle. Cut a wood plug with a mating bevel and glue it in place with a good quality construction adhesive like LePage or Loctite PL series.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
