jjrbus
Feb 24, 2022Explorer
I would not remove the disconnect to add manual circuit breakers. I will add a manual circuit breaker in lieu of an automatic breaker. There are circuit breakers at the isolator upfront, there are breakers at the disconnect switch and no breaker at the house battery. House battery was relocated and they likely saw no reason for a breaker on that end of the wire.
This is a new to me Raodtrek and trying to wrap my head around the reason for the disconnect. It appears the disconnect is to keep the house battery from discharging when not in use?
Monitor shunt? Wonder if I have one??
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
