Sewer Hose Storage Project - Another Fence Post Mod - Pics
Teamfour
Thanks to all the posts on this forum showing sewer hose storage ideas using a fence post, I built mine today. You will see in the pics that I decided to use rivets for most all fastener requirements. By strategically placing the fittings and cutting a few notches, I was able to put the rivet heads to the outside for a clean look. I will install on the TT this Friday and will add more pics then.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 locker, 3,295 Payload
2014 Salem Hemisphere 282RK 7.8k lbs loaded, Equal-i-zer WDH
40 REPLIES 40
Carb_Cleaner
Nice work.
This thread has some ideas, too:
Clicky
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27009642/srt/pa/pging/1/page/1.cfm
'13 F250XL SC gas 4x4 8', Camper & Plow packages, StableLoads, LT285/65R-18 Goodyear Wrangler A/T Adventure, 18x9 Ultra Motorsports "Phantom" wheels
'12 Wolf Creek 850 TC Coleman Polar Cub 9.2k A/C, 90 watt solar, dual propane & batteries, Maggie Rack
BarneyS
Stalvo wrote:
How is everyone attaching the post cover under their trailer?
Here is how I did it. I made three carriers-one for myself and one for each of my sons. I used strapping material I purchased at Home Depot. The brackets are bolted into the bottom of the trailer frame.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Stalvo
The Stalveys
Michael, Amy, Reese & Ethan
2015 Ram 2500 Crew Cab 4WD w/ 6.4L gas
2013 Heartland 25BH
Lakejumper
I know this is an old thread but I also couldn't find the 5" fence post sleeve at Lowe's or HomeDepot. I found it at a ranch supply store. Thanks for sharing pics of the project. I made mine last week.
Great idea!
Lakejumper
2016 Winnebago Vista LX 30T
2012 Chevy Equinox
Carb_Cleaner
synergy_58 wrote:
...so Lowes ordered one ...
Did you order end caps, too?
When I picked up my 5x5 sleeve, Home Depot didn't have the 5x5 caps. Had to order them.
4x4FF
synergy_58 wrote:
Carb Cleaner wrote:
synergy_58 wrote:
So I ran over to Lowes to get materials to build this. I found the gutter stuff but the fence post isn't big enough to house the gutter. The staff dug through everything but coouldn't find any plastic fence posts that were big enough to take a gutter. Any suggestions?
Thanks.
I don't think Lowe's carries the 5x5 cover. Home Depot has the cover, HERE. Home Depot doesn't stock the symetrical gutter that's used for a tray. Gotta get the gutter at Lowe's.
What a challenge to find the fence post. Yup, Lowes discontinued carrying the 5" post sleeves. They said no one was buying them, too much slack in the sleeves to work well on fence posts; that's what they said. BUT...the company still makes them and so Lowes ordered one for me; four to six week delivery time (to Anchorage, AK). At least I can still get one, eventually.
I guess I better go ahead and buy the gutter before Lowes stops carrying them too!
I just bought the 5x5 post cover and gutter at my Lowes last night. It must be a regional thing.
'07 39' Pilgrim Open Road 5th Wheel
'18 F350 Platinum 6.7 Powerstroke
synergy_58
Carb Cleaner wrote:
Thanks.
[img/Users/Frank/Pictures/iPhoto Library_2/Originals/2014/Apr 2, 2014/2009_1306_Nav_BlueMoon.jpg[img]
kenboat
At our store they couldnt find the 5" either. The guy was over by fence material. The 5" was over by privacy fence panels stuff, panels and such.
1999 Ford F250 SuperDuty CC LB 7.3 TD
2008 KZ Sportsmen S245RL2
1956 Owens Outboard Wooden runabout boat
nvreloader
When drilling holes in the tube, keep the holes 1/8" in diameter and only drill on the corners and end caps, that way the Stinky Slinky won't have a burrs to rub on etc and tear things up.
By using the 1/8" drill size, keeps the "Stingers" out etc.
Tia,
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
BarneyS
camper19709 wrote:
Nice idea! I have seen other threads about this and they posted about drilling holes to let the water drain and the hose to dry out. My question would be. Should I be worried about wasps or bees going in and making a nest in the tube?
I have had this mod on my trailers for the past 6 or 7 years. I drilled holes in the tube for drainage and to help things dry out and have never had a single problem with wasps or insects of any kind making a home in there.
Barney
Not towing now.
camper19709
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
Carb_Cleaner
Thanks.
C_B_
kellertx5er wrote:
Is there any provision to allow water to drain out?
I'm on my second sewer hos holder. First was on my 2003 Cardinal.
Second is on my 2013 Cedar Creek.
Both trays were sealed at the ends. After flushing hose with clean water and returning Rhinoflex hose to it's shortest position I give it a couple of taps on the ground. The little bit of moisture left in the hose has never caused a smell or any other problem problem.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
kellertx5er
Keller TX
'19 Chevy 2500HD 6.0L
'09 Outback Sydney 321FRL 5er
SUPPORT TEXAS STATE PARKS
nvreloader
IIRR,
I the fence post is 5" square, the type that gose over a standard 4" square wooden fence post, standard gutter 3/4" will fit inside this 5" plastic fence post.
Tia,
Don
