beef56's avatar
beef56
Shower
I would like to install a quick connect coupler system for my outside shower. Any ideas if this is possible or where I might buy this hardware. Thanks
  • If you do put that on, point it upward so it will drain away rather than form a water pool that would freeze. Most quick disconnects have a spring loaded device to prevent flow once it is disconnected, and gravity will pull the water out if you align it properly.
  • Take off your hose,take off the shower head go to any big box home store and tell the person in plumbing what you wanna do.'
    Easy as pie.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,369 PostsLatest Activity: May 10, 2025
