acritzer's avatar
acritzer
Mar 24, 2024
Slide out hell!
Messed up on this one!  I’ll make it short and skip the backstory. The slide out it stuck in the out position, I tried disconnecting the motors to manually push it in but can’t seem to manage it. I’m trying to avoid totally tearing into things.
Coachmen Apex, can’t really get a good look or access to the motors. Should I bite the bullet and tear off the exterior flashing?
  • You can use the manual override on shwintech or undo one screw on each motor, pop them up and push in the slide.
  • Many (most) slides allow you to crank them in by turning the square bar under the slide.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
