gahanorama's avatar
gahanorama
Test AC before installing on roof
Hi there, in process of souping up a 1977 dodge sportsman. Bought a dometic brisk II and installed a softstartrv- we have a 25000 watt generator. The AC is sitting in my house and I wanted to test it before installing in roof of MH. How can I plug it in to household outlet? Can I temporarily splice the power wired to the 110 plug? I have the cut end of an old plug. Thanks!
  • x2 I,ve done this more than once. 12g wire on start up they pull a lot of amps. let it run half hour or less if things sound good watch it don,t vibrate off the bench.
  • That should work for testing, provided your cord is of sufficient ampacity. I'd want 12 gauge, or 14 gauge at a bare minimum. Many power cords for stuff and extension cords are only 16 or 18 gauge, even when the outer case looks pretty big and heavy. Scrutinizing the labeling embossed on the cable sheath should reveal all. Try to use a 20A circuit in your house and have little if anything else loading it.
    This is, of course, just for fairly brief testing, not for any long-term usage.
About DIY Maintenance
