Greasie_Grissom
Jun 03, 2013Explorer
There used to be a co.called Strawline that made 12 v stove vents.
The moter & fan was on the inside wall the cover on the outside wall.
The switch was a type that was closed when the cover was closed.The
cover had a chain like some lights use.The kind with little balls
with pins between the balls.The inside frame had a slot for the chain
to sit in.To use you lifted the chain & the cover being spring loaded
the fan turned on.Cut a hole wire up & you got it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
