โMar-04-2012 10:52 AM
โMar-25-2013 04:07 AM
โMar-24-2013 07:26 PM
โMar-24-2013 05:32 PM
โMar-24-2013 12:34 PM
I am nine screws and two wire connections away from being my own utility.
โMar-24-2013 11:07 AM
โMar-24-2013 10:55 AM
โMar-24-2013 10:40 AM
โMar-24-2013 10:00 AM
โMar-23-2013 06:24 PM
โMar-22-2013 12:11 AM
Are you asking for recommendations?
weighed over 50 lbs., (oops, 22.72 kg,)
โMar-21-2013 10:49 PM
โMar-21-2013 10:06 PM
Moderator edit to re-size pictures to forum limit of 640px maximum size.
โMar-20-2013 06:30 PM
and yet NASA is using metric system,go figure.
โMar-20-2013 05:32 PM
DeadeyeLefty wrote:
Gijoecam, welcome!
As far as the weight goes, I'm shooting for as light as I possible. My strength requirement assumes that the trailer is loaded to gross all the time (which is in itself a fluid number at this stage...to a point), but if the gross stays under 700kg (1400#...for those in the one country not using metric, hehe...) registration is much simpler.
If I go much over that, I'll obviously upgrade as required. I'm currently building to the shockingly scarce standards for trailers and to ABYC ('code' for boats) when in doubt.
Hard numbers: I'm looking for 1000# + stores, batteries and water. I doubt I'll make that, but it's the target. That said, each wall panel is about 10 lbs and they're about 3'X7'. The 6 1/2 X 11' SIP floor was about 60 lbs IIRC.
Currently I can lift the tongue with one hand on the cinder blocks under the back corners and temporary 1X4 ring frames inside. I've been wanting to drop it off the blocks and see how it's doing weight-wise but I have it perfectly level right now ๐ I've already talked to the guys at the landfill about using their scale to weigh it so I'll get weights in a few configurations. Can't tow it till the shell is done though !
Free Radical, my Japanese is worse than my Russian...and I don't even speak Russian... I too would like to hear what they're saying. I was amazed at how it seemed to eat the smoke as well: like it's actually absorbing the heat.
I wonder if, like Halon, it's almost as bad for you as the fire is ?recycler wrote:
i like the idea of turning it to a smoker if it does not work.. salmon would be good..
Salmon is always be good...
For camping I'm thinking about putting folding (or tabletop) legs onto mine.
That's a cheap Broil King (~$150 IIRC) albeit repainted and the slats stained mahog and sealed. It works as either a charcoal grill or a side draft smoker. Being so small it takes a while to figure out how to keep the heat even but it does a great job once you figure that out.
โMar-19-2013 06:58 PM
