"westend" wrote:
Remember, no smoking meat with leftover extruded poly
Sssshhhh, cyanide gas was the 'secret ingredient' in Grandpa's brine recipe....
Okay, sorry for the long one here but I tried to answer questions in as much detail as I could so you can see how I came to the design I did. At least I peppered it with pics and even a video (dial up users: apologies!)
free radical wrote:
I did it from plywood coated with epoxy instead.
Nothing wrong with that - wood is the original composite and is an amazing material to build with. Epoxy's compatibility with it made it possible for anyone with only moderate skill to build a boat (or an RV!). Part of the reason I'm enjoying this is that it gives me the chance to try out different ideas and techniques than I get to in my paid gig and because I've always gotten a kick out of all the different things you can do with glass simply by varying the layup a little.
Unfortunately, that's at a cost for me too: that's the only reason the build is going so slowly. I could go out tomorrow and by 2X2's and 1/4" ply and be camping in a month of weekends, or just go and buy a small TT, but I'm building for the sake of the build.
Who would have guessed that it took so darn many beer to build a little trailer though ? :B
"TachDriver" wrote:
Where were you when I was rebuilding my fiberglass boat? lol.
Let me guess, replacing rotten wooden stringers or transom core ?
Done waaay too many of those - I feel your pain.
"free radical" wrote:
Wondering how strong is this type of structure, have you done any tests on how much weight can the roof withstand?
"TachDriver" wrote:
...will you be using stringers and ribs to support the ceiling?
As far as the roof structure goes, I do have a transverse stringer to carry the weight of the front of the solar array (such as it is) to the outer walls. The rest of that load will be carried by the back wall. From there, the roof begins to camber up the the vent. The curb for the vent is glassed as well, since it will form a load ring with unidirectional fabric in the layup. I'll have about 60# (IIRC) of solar up on the roof and, even if I wanted a luggage rack up there, there's no room - this is only a 13' trailer overall. The majority of the loading will actually be from the trailer trying to flex as it goes down the road, unlike a build from individual members (like studs and trusses) where the walls hold up the roof.
I'm trying to build it as much of a true monocoque structure as I can. By using inner and outer skins of glass held a fixed distance apart by the foam, the two skins working against each other can carry insane amounts of load in proportion to the weight of the materials. The added plus is that the materials themselves are light enough that they don't add much loading. That said, there is one full height bulkead where the 'nose cone' starts and lower cabinetry that will contribute to the stiffness. I'm debating whether or not to glass the tanks in or not as well: they will add to the stiffness but may also flex, compromising the joints. Regardless, that decision is a long way down the road yet.
I wanted to create what was essentially an egg-within-an-egg. I had several reasons for canting the upper and lower corners of the sidewall back in toward the frame, one of which was to help carry vertical roof loads (solar panels, snow) to the frame. A benefit of this shape was that the corners help to stiffen the sidewalls as well. With the heavier layup over corners and seams I am providing 'bands' that make up a grid. Given how strong the matrix is in compression, that means essentially a cage made up of intersecting rings if one were to envision it without the foam. From a structural standpoint, the foam is there to keep the 'bands' locked together so they can't deform.
This is how most performance composites start out, but I have severely scaled it down to something that I can do in the space I have and within my budget (such as it is, lol).
That de-rating is exactly why I started with testing...
Some of the first tests I did were of the bond between the glass skin and the foam, and a combustion test. I learned some interesting things from each that may seem counter intuitive. The former is back on the first couple pages, the deflection testing was done the same way I did for the door panel.
...since this stuff is so flammable,if you plan on cooking inside is to carry TWO fire extinguishers...
You know, I thought long and hard about ever using this stuff for that very reason. One of the things I learned is that there is a different fire rating for US vs Canadian products: the US version has an exterior fire retardant coating that Canadian products don't. Apparently that's in part because under code in the US you can use it in far more places than you can in Canada. That said, it depends on whether the store has sourced it domestically or not. I looked for a scrap of the US stuff tonight that I could burn, to be sure I was comparing apples to apples, but it got too dark out back.
Here are a couple pieces of the first test I did (made in US product):
The foam melted and burned with open flame only as long as the heat (torch) was on it. **I'll replace the pic with a video after I poke through the scrap foam pile**
Here's a short video clip of the made in Canada stuff. It still takes a bit to get going, but it does support combustion. As you can see, it didn't take much to put it out.
I'm not saying anything because you wouldn't be able to make it out through the mask...
My concern is not just about open fire, but the smoke that the foam gives off is a thick acrid cloud that I imagine would incapacitate one pretty quickly so egress is my primary concern rather than fighting a fire. The compination, epoxy and paints is a toxic soup that you don't want to be breathing while you're trying t put out a fire.
Because the combustion appliances are all between the bed and the door, the back window has panes big enough to crawl through. They are old single pane jalousie windows, so in a pinch they will make a hole big enough to get out through. I am also toying with the idea of a swing-out frame like on a bus.
I'm allowing all kinds of clearance around the stove and the forward bulkhead will be lined with plywood and metal. If I can't find an appliance carcass at the scrap yard to cut a couple pieces of white enameled steel from (or maybe even stainless), I'll use something like aluminum flashing - the point is that there will be metal flashing to keep anything that's actively burning contained on the stove top.
Where the oven vent comes up at the back of the stove, I have about 4" of space to the outer wall. That space will serve as a thermal break between the steel and inside of the outer wall. If you look at the picture of the countertop, that's the skinny part of the L at the back of the stove cutout.
After I cleaned and tested the stove, I found that, with the oven at 300 degrees (measured), the outside of the sides were just on the verge of being uncomfortable to touch after 1/2 hour. Based on the testing I did of the laminate, upping the 1/8 ply to 1/4" and using metal rather than laminate should more than protect the foam core.
Epoxy softens at 100 degC, so 80 is about the limit. If testing shows that to be inadequate, the plan is to float the steel on top of some rockwool firestop, but that will thicken the bulkhead at least an inch which I want to avoid...but not at the expense of safety.
As far as the actual safety equipment is concerned, I am planning on having 2 2-1/2 BC extinguishers aboard: one at the bed and one at the door.
There will also be a smoke detector at the ceiling and a CO monitor below the level of the bed. I recently saw a hard-mount kitchen extinguisher that one mounts above the stove for flash fires but I haven't checked them out yet (Kidde, I think?) I get all that stuff cheap through work so it just makes sense to use it.
One upgrade down the road is a gas sniffer in the toe kick and shutoff solenoid at the tank. I've put a bunch of Fireboy S2 kits in boats and they seem to be pretty reliable.
All that being said, most of the cooking will likely be done outside under an awning because, with how well insulated this thing is, it will get pretty warm in there. I'll pack a folding table and a cookstove, and we'll have the outside bevvie cooler but am still building as though all the cooking will be done inside. I will also be installing a wall mount gas lantern over the table, as much for heat as for light. I am blown away that, even seams between glassed and unglassed panels, no window in the door, and open wheel wells, a propane lantern heats the interior from around freezing to T-shirt comfort in about an hour. That will drop as I replace foam with glass and due to the ventilation needed to deal with the humidity but it bodes well for warmth. Besides, my wife and I and our 70lb Golden will probably warm it up pretty quickly too
๐
