Sort By
- myredracerExplorer IIYou may have trouble getting something with a similar color. Can also try a plywood specialty shop if you have one nearby. RVs use luan plywood for it's lightness but is 1/8" thick like other "ordinary" plywoods.
Wall plywood in RVs is stapled which is kinda good because it makes it easy to pull off but you could use some PL400 adhesive and use a few dollops of it on studs. If you overdo it, you'll have a big job to get it off. PL400 will be available where you buy plywood (except at RV places). - old_idaho_guyExplorerWe used paneling from Home Depot. $20 for a 4 x 8 sheet. Liquid nails or screws to hold it. Easy to cut.
- agesilausExplorer IIIHow is RV wall paneling different from the stuff sold in the big box hardware stores? Try Lowes/Home Depot
- HammerboyExplorer
larandjane wrote:
Any one know where to purchase rv vinyl wall paneling in Tulsa area.
Why not start with calling a couple local RV dealers? If they can't get it maybe they could at least steer you in the right direction.
Dan
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,370 PostsLatest Activity: May 11, 2025
