SoundGuy
May 31, 2017Explorer
Dutch_12078 wrote:
I used coiled 40" soft shower head hoses and foam pipe insulation connected to our pump's inlet and outlet to drastically quiet it down. The hose on the inlet side dampens mechanical pump vibration transmission to the hard pipes ...
IF the pump intake is hard wall PEX but in most instances it's already soft wall braided hose, ergo the reason that adding more does little.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
