Bobbo
Jun 01, 2017Explorer II
The accumulator tank after the filter will try to push water backward through the filter when pressure is low before the filter. If you want to do this, you need a backflow check valve between the filter and the second accumulator tank.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
