SoundGuy
Jun 06, 2017Explorer
crcr wrote:
Thanks for all SoundGuy and Lynnmor, appreciate it. So I'm thinking two of these compression for Pex to Barb fitting for soft braided hose fittings might just fill the bill for my application. What do you think? Am I on the right track now?
That's one alternative but as I said earlier I don't see the need to cut the PEX at all if you can disconnect it from the pump, leave the PEX connector as is, and simply connect your soft braided hose to that connector, using adapters if need be.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
