raztec's avatar
raztec
Jun 16, 2016
what gauge wire between two batteries?
I'm adding a second AGM battery to my truck camper.
It's going to be under the bench seat in the back on the other side from the 1st battery. So their distance will be about at least 10-12 feet from each other.
What gauge wire should I use between the batteries?
Also, as it will be a Trojan AGM battery, does it need to have a plastic container or be vented in any way?
Thanks a bunch for your replies,
Raz
About DIY Maintenance
