westend
Jul 23, 2014Explorer
The problem with using contact cement is that if anything isn't positioned correctly, it can be a bear to remove and reposition. If the fiberglass exterior panel is rigid, this will be less of a problem. I would lay the panel down in increments and roll the fiberglass into the luan. I'd probably also fashion some type of brace or clamp to keep pressure on the exterior panel.
Fastening the luan to the framing would be an excellent idea.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,354 PostsLatest Activity: Mar 15, 2025
