Erie_Tom
May 14, 2014Explorer
I need to run ham radio coax in for the two radios I use. I went to Lowes and the plumbing section. Looking for a threaded cap and then a threaded section of 1 1/2 PVC. Found a piece about 2 inch threaded and then a cap for it. Through one of the storage compartments doors close to where I wanted the radios I drill a hole in the compartment door. Measured twice for the hole and then sealed it with caulk that locked the section into place. On the outside the cap screws on with a gassketthat I formed and this is how it seals all weather out going down the road. To use the coax just unscrew the cap and pull out the coax which is right in side of the compartment door and direct it to the antennas.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
