Bud_Baker's avatar
Bud_Baker
Winnebago Navion Roof Vent
Hello Ladies and Gentleman. New here and ran into a problem. Hope someone might have addressed this before.
I have a 2012 Winnebago Navion. I bought the maxxfan Deluxe Model 7500K with remote to replace the existing roof vent. I found that the roof vent that Winnebago installs does not screw onto the outside roof, but is held in place from the inside roof Trim Ring. Is there a different Model I need to get from Maxxair to use in this application or can the one I bought be used? Thank You, Bud
  • I installed 3 different Maxxfans in my ClassC and the trim rings only attach to the ceiling not the housing so they won’t help hold it in. The old fans I removed where attached to an aluminum frame around the hole.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,358 PostsLatest Activity: Apr 04, 2025
