SkullAndSquirre
Jul 13, 2015Explorer
Thanks for the replies team!!
I installed the kit over the weekend.
Wire Route:
Solar Panel>
Sealed Junction box on roof>
Hole through junction box into bedroom cabinet>
Bedroom Cabinet into Family Room Cabinet>
Family Room Cabinet into water pump cabinet surround>
Renogy controller on water pump cabinet exterior>
Back into water pump cabinet large fuse>
Battery battery bay>
15 amp fuse>
Battery..
Total run, appx. 9-10 feet.
Avoided Problems:
-Roof is thinner at the angle joint between the bedroom and main room, try not to mount too close to the joint.
-Mount on the front of the RV, backing in (for us) usually means shade on the back end of the trailer.
-Acorns dropping from the trees, now worried about them hitting the panels, moved trailer.
-Didn't need more wire than the kit included, but one wrong cut and it would have been another trip.
-Decided to run straight down from panels through cabinet to batts, saving time, wire and frustration.
Unanticipated:
-No fuse in kit, head to store.
-Battery cable kit too big ga. for controller, head to store.
-Added spacers under controller to help heat dispersion, head to store.
-Hard to get to screws, needed flex drive shaft for drill, head to store.
Potential problems:
-Roof needs maintenance soon.
-Cheapo controller, is it working correctly? Bought voltage meter, don't know how to use it.. lol.
-Battery bay is tight, need to move it.
-Renogy controller is in a nook, watching to see if it warms up.
Wire Route:
Solar Panel>
15 amp fuse>
Battery..
Avoided Problems:
Unanticipated:
Potential problems:
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,354 PostsLatest Activity: Mar 15, 2025
