12 volt rv battery vs 6 volt gc batteries
garycq
Lately I have been having trouble with 6 volt golf cart batteries and seriously considering going to two 12 volt AGM deep cycle rechargeable batteries. Has anybody had the same frustration that I have had using two golf cart batteries and gone over to the two 12 volt batteries. I have two solar panels which should keep them charged.
GaryCQ
Arctic Fox '07 29-5T 5th wheel
2001 CTD Ram 2500
23 REPLIES 23
WyoTraveler
These batteries may have been damaged by being discharged and not maintained. If you buy new batteries you may have the same problem. You need to monitor charging current and water periodically. I realize sometimes this a problem if an RV is in storage and can't be plugged in.
enblethen
The kill switch may not shut everything off.
The batteries must be fully charged prior to going into storage.
I would have removed the batteries.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
2oldman
What was the voltage reading on them before storage?
garycq
The batteries were new Trojan 105 that worked when first installed. Didn't use them for several month's while in storage. Used the kill switch on the rig. When I went to do some work on it (water and was ok) the batteries didn't work so I removed them to take to my mechanic to charge. The next day he said they wouldn't hold a charge. I talked to a neighbor who is an electrical engineer and he said it could be anything including something in the trailer or even something with the batteries but he just didn't know. I can't afford this type of thing and that is why I'm considering going back to the 12 volt batteries which came with the trailer.
2001 CTD Ram 2500
Dakota98
2oldman wrote:
Without knowing what kind of trouble, it's hard to say. I have a million threads on the 12v vs 6v subject.
X2
Maybe by telling the Forum the age of the batteries, type of trouble you're having & by what means of charging you rely on, may help.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
Crazy_Ray
Gary could tell about the PROBLEMS you are having, then you might get some HELP
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
C_Schomer
I never had problems til I got Costco 6v's. I got 8 yrs out of T105s and 8 yrs out of Napa HD 6v's, both being maintained by a charge wizard. I just took out my Costcos this morning and checked with a hydrometer... exactly 2 yrs old and they are junk! They wouldn't even run the furnace one cycle this weekend. They were maintained by a solar smart charger. I might go back to plugging in so the charge wizard keeps them up.
Even when the costcos were new they only had 2/3 the capacity of the other two brands. I think the problem is partly Costco and partly the solar charger not being able to do the job that the charge wizard/converter can do. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
enblethen
Same problems can exist whether it is two 6 volters or two 12 volters. Bad, poor connections, or incorrectly connected.
What is the problem or issue that you have?
Bud
USAF Retired
Pace Arrow
2oldman
