larry barnhart wrote:
Sad to see a MS with tires that cannot handle the load. I brought into our park two times a MS with mission E range tires. so if the G-614 tires couldn't handle the load why were they on it ??
I've owned Mobile Suites since 2004 and have never seen or heard of one with anything other than 16" Goodyear G614s (earlier models with 7K axles), 17.5" Michelin XTAs (briefly) or 17.5" Goodyear G114s. If you found one with E-rated Mission tires, I can only surmise that they were installed by a less-than-ethical tire dealer since the tires must meet the minimum requirements shown on the GVWR/GAWR/tire size, load rating and inflation pressure label.
The pre-2007/2008 Goodyear G614 tires had a tread separation problem that affected users of this tire on any number of heavier 5th wheels - the problem was not exclusive to DRV units. Supposedly, the later G614s utilized a different design and/or manufacturing process and have proved to be reliable. After 2 tread separations in 2007 on the early G614s on our 2004 MS, Goodyear replaced all 4 tires, and the replacement G614s gave no problem until 2010 when I replaced them with 17.5" Michelin XTAs for a summer trip across Texas, New Mexico and Arizona. The Michelins were also problem-free up to the time we traded for our current 2014.5 MS in May 2014.
Rusty
