clinnhapp's avatar
clinnhapp
2002 Big sky montana 3670 missing fridge and stove
Hello I have a 2002 big sky Montana 3670. On May 15th 2014 someone broke in my trailer stole my fridge, stove, battery, outside covers, broke my counter top and scratched my floor. I don't have the make and model of the fridge and stove since they are missing. I called numerous places and no one is able to help. If you own this model can you please send me the make and model of the two appliances. I will be forever grateful. thanks
  • You could also go look at some used Montana's and compare measurements to see if they are same. If so just get the numbers off of those appliances. Good luck, John
  • If you remember the brand of the appliances start looking up their specs and compare to your dimensions.
  • Any rv fridge and stove that fits the opening will work...does not have to be OEM.
  • Your fridge is most likely the standard size. It isn't a 2 door wide one? Then just go buy a standard fridge. Same with stove.
  • I did call keystone and they said that in their systems it goes only to 2004 and they could not help. All local companies could not find matching stuff so the insurance paid me out and is letting me do all the work. The trailer was purchased used and did not come with books. So make sure to keep record of all your stuff, you never know what can happen. I will keep trying.
    Sir, If you bought this vehicle new you should have owners manuals. Most of the time they come with the brand information booklets for your appliances with all of the other paperwork. Wish you good luck and Happy Camping after repairs. :B
  • Call Keystone Customer relations 866-425-4369.Have your VIN ready. They should be able to tell you exactly what is installed in your Model and year.
  • Sorry to hear this happened to you.
    I would turn it over to ins. Then you just have to make an appt with a dealer and have the items installed. Note that the fridge and stove are common size items that can easily be matched up once the size of the openings are measured.
    I would have a counter shop repair or replace the counter top - not a dealer.
