TymTrvlr1's avatar
TymTrvlr1
2007 Wildcat RLBS Window replacement
Had break-in attempt at storage lot. Damaged bedroom window at the weep hole when they pried it down with screwdriver, no broken glass. Will try to repair, but if window breaks will need new one. Anyone know how to search web for window sizes, or is the default a dealer parts supply order? Can't find anything concerning window specs on line at Forrest River??
  • easy to remove window by removing all screws from interior trim ring and then slip a putty knife under the outside edges and window will pop out. Have someone inside to push if needed and someone outside. Then measure the rough opening size, or look on frame of window itself for a sticker that will indicate size. tons of them on ebay way cheaper than buying from dealer. You don't need the dealer or manufacturer for this. I just bought a tinted one for my 09 Montana for 50 bucks. wouldn't even try to repair at that price, just put in a new one. Once you find your size just go to ebay and type in "rv window" and your size
