2008 WW Warrior Rear upper tail light out
Paul-n-Julie_WW
We have a 2008 WW with a rear upper tail light out? Has anyone else had to replace the bulb. We can not figure out how to get in and replace? Any recommendations?
2 REPLIES 2
Camorhino
The above would be the best way, otherwise, the inside wall panel that is above the top door opening has to be removed to access the back of the lights.
72goat
Remove the flood light next to the tail light, then you can reach in and change the bulb.
