โJul-14-2017 07:38 PM
โJul-17-2017 09:34 AM
โJul-16-2017 04:19 PM
GoPackGo wrote:Me Again wrote:
So what happen to the OP? I gave him the solution to his issue, yet we see no response. Chris
I truly appreciate the help and you very well may have solved my problem BUT - I full time and had to move to a new location yesterday so I was driving, then setting up, then dinner, THEN I read your post. Decided not to attempt a fix in the dark.
So give me a chance to check it out - probably today.
Thanks again.
โJul-16-2017 12:27 PM
โJul-16-2017 11:26 AM
โJul-16-2017 08:31 AM
โJul-16-2017 08:21 AM
โJul-15-2017 08:24 AM
โJul-15-2017 08:15 AM
โJul-15-2017 04:56 AM
โJul-14-2017 08:24 PM
rjxj wrote:
Did you get all the wires back on the battery properly? Were there two positive wires at the positive terminal?
โJul-14-2017 08:16 PM
โJul-14-2017 07:59 PM
cmeade wrote:
I had your problem but with my 2010 ram 3500. Batteries got hot and one was swollen and steaming from vent/caps.. I replaced both batteries and all is fine. My WAG is the old battery is not playing well with the new one and slides and leveling are on new battery and lites and fridge (inverter if residential) are on old battery and cable between batteries is small enough to not allow rapid discharge of the stronger/new battery. Pull both batteries and go to place you bought new battery from and have them tested. If new battery was damaged by bad battery then you need two new batteries and all will be fine. Also could be bad connection between batteries??
โJul-14-2017 07:57 PM
โJul-14-2017 07:55 PM
