2015 3500 Ram
T-Trucker
Hi all have a friend looking at a 2015 3500 Ram Dually,He has a Cedar Creek Fiver 16,000lbs,the the is a diesel but only has a 3:42 rear ends in it,is that enough ratio for a 16000 lb trailer,or should he stick with 3:73s or 4:10s,Thx.for all opinions. T-Trucker.
30 REPLIES 30
jnharley
We have ordered our last 3 Ram duallys (2004, 2012, 2015). All arrived in about 6 weeks. That way we get exactly what we want on the truck which always includes a 4:10 rear end.
2015 Dodge Dually
2012 NuWa Discover America 355CK
TxGearhead
Pulling the 12,000# Montana I sometimes forget, for a long time, to use tow/haul. I only occasionally lock out 6th gear. Aisin. Go for it.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
RustyJC
Most of the Ram 3500 duallies I see on the lot here in Texas are 3.73 trucks. There are some 3.42 trucks (the standard axle ratio - thanks EPA and CAFE standards), but 4.10s are hard to find. I had to drive to Alabama to buy the truck in my signature that I found on an internet search. Normally I have to order them to get the 4.10s.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
tinner12002
T-Trucker wrote:
Thx,guys for the comments,He has backed off that truck,but would it be feasible to change out the gears in the rear ends,if so does anybody got a cost idea,he really likes the truck itself except for the gearing.Thx again.
Probably be better off just to look for a different truck rather than change all the gearing.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
tinner12002
donn0128 wrote:
Love my 4.10 rear end. Personally I would not get any less than a 3.72, but you have to understand ratios, torque, and load handling further to see my point. The 3.42 will work, but he might be towing in 5th when I tow easily in 6thOD.
Big X2 here also!
2018 Raptor 428SP
Cummins12V98
Me Again wrote:
boshog wrote:
I've read were guys have received quotes from dealers and private shops for gear axle ratio changes, if memory serves me correct, the rear axle was around $2,200 and do not remember the front axle cost, that is if he has 4x4.
Search around on the Cummins forum this is where I've seen a few threads discussing axle ratio changes.
That would be full retail for both ends of a 4x4. Remember the diff only then has a one year parts warranty. I believe Dave Smith was going to do cummins12V98 2011 for 1500. Chris
Yes, $1,550.
A great deal but as I have said the truck performed great with the 3.42's towing a combined 29K Just took it easy on grades taking off. Oisin would have cured that small issue!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me_Again
boshog
T-Trucker
HighSpeedAlumin
I have a 2015 RAM SRW with a 3.42 axle that pulls a 14k pound trailer. We pulled through Colorado up the Brekenridge pass at 11500 feet with switchbacks without any problems at all. The only thing noticeable was the engine/transmission temps increasing 10 degrees staying well below the max limit. When not towing we get great mileage. The 3.42 should be fine.
2015 Ram 3500 SRW Laramie Longhorn W/ Air Suspension.
2015 Grand Design Reflection 323BHS
Old-Biscuit
boshog wrote:
The gear you are in when towing isn't important, what is important is the engine RPM, you want to be in the engine's powerband. If you are running a Cummins you can download their Powerspec software which will tell you the optimal engine RPMs. For my 3500 SRW Cummins 3:42, the optimal powerband when towing my 15,000 pound fiver is 1,600 to 1,800 RPMs. This equates to fifth gear when running 50 to 60 MPH.
YEP......
My 5.9L with 48RE and 4:10 tows my 14K 5vr in 4th (OD) at 1850 RPM (62 mph) 11.5 mpg
boshog
minnow
Dirtydan, I think that's the Canadian Window sticker whose prices are much higher than a comparable truck for sale here.
Old-Biscuit
MudChucker wrote:
minnow wrote:
I often wondered what kind of salaries one makes in Canada. seems prices up there are astronomical. 2 bedroom homes that share walls with neighbors selling for $700,000.
Your comment is true of most major cities in Canada.
I don't know how the average income folks do it either.
That's $525K US.
So some can be said of housing in some major US Cities in the Northeast and the West
