โJan-25-2014 05:43 AM
โJan-25-2014 08:01 PM
โJan-25-2014 07:40 PM
โJan-25-2014 07:15 PM
Cummins12V98 wrote:stro1965 wrote:
I pull a 38' KZ, dry pin weight is 1900 lbs or so, I think I am kinda pushing the limits.
"kinda" Why quote dry pin weight? Do you know what your TV's rear axle weighs fully loaded? If not you should.
You know you are in Dually territory. Possibly a newer 3500 SRW?
โJan-25-2014 04:38 PM
โJan-25-2014 04:01 PM
โJan-25-2014 03:54 PM
lynndiwagon wrote:
Like the guy said "Airbags and 19.5"s". Look at my sig.
I also have Airlift 5000 bags. Tires are rated at 4500lbs each at 110psi. Just towed from OKC to Mcallen, got 11.5mpg. No white knuckle.
โJan-25-2014 02:42 PM
โJan-25-2014 12:30 PM
โJan-25-2014 11:32 AM
goducks10 wrote:dennis1949 wrote:
I pull a 3125 Blue Ridge.. Truck does not know 5th wheel is back there. Get about 12.5 mpg if run between 60 and 63. Total weight of truck and camper is 12,300 lbs.
You mean the Blue Ridge weighs 12,300.
โJan-25-2014 11:31 AM
Me Again wrote:
I know when my 12,400 5er is back there, the brick truck rides a lot better. And actually tracks on the highway better, with less steering input. Chris
โJan-25-2014 11:23 AM
โJan-25-2014 10:55 AM
โJan-25-2014 10:50 AM
โJan-25-2014 09:58 AM
rhagfo wrote:Me Again wrote:Cummins12V98 wrote:
Chris
What does your combo weigh?
When I towed with my 98 12V Cummins 2500 4X4 my combined weight was 20,500# the RV was a 2002 32.5' Avion Platinum. The truck sat level without air bags. I ran stock 3rd gen tires and wheels. Can't find my weight slips but it handled the load very well but I always said that was the limit for me. Anything longer or heavier was going to be a dually.
Sent you a PM. My 2001.5 was built like a SRW 1T, but Dodge did not tag it as such. Only in 2003 did they start officially building SRW 1T's, and they had tires of a lesser capacity than my 2001.5 optional 265's.
Chris
They just don't make them like those 2nd Gen Ram/Cummins any more! The same here 01 Ram 2500 towing 05 Copper Canyon 293 FWSLS run about 2,100 pin loded and 19,000 GCVW. NO bags or Timberns, sits level, run hills all the time pull great, STOPs great goes great! The Camper Package makes all the difference, 3500 running gear and springs!
โJan-25-2014 08:53 AM
