โMar-02-2018 06:23 PM
โMar-07-2018 09:22 AM
JIMNLIN wrote:
Dexter axle;
The Gross Axle Weight Rating (GAWR) of your running gear is determined by the lowest rated component in the assembly. The capacity of the wheel, tire, axle, brake, springs/rubber and hub are all considered.
This from AL/KO axles says much the same:
** Weigh the trailer after it is fully loaded and ready for use.
Axles, brakes, wheels, tires, frames and suspension components are
designed to carry a specific maximum weight. Locate the VIN
(Vehicle Identification Number) plate on the trailer. It will show the
GVWR (Gross Vehicle Weight Rating). The GVWR is the total
amount your trailer (including tongue weight) can weigh when it is
completely loaded including holding tanks, propane etc. The GAWR
(Gross Axle Weight Rating) is the maximum load that the axles will
carry and the maximum load the brakes will stop.**
โMar-07-2018 09:04 AM
azdryheat wrote:On my Voltage 3950 with 3 x 7000lb axles, the kingpin is rated max 19000. There may be other things too.
My Voltage has the same thing: 3x7000 pound axles and a 19,000 GVWR. Glad one of cares enough to pose the question.
โMar-06-2018 05:26 AM
โMar-05-2018 06:16 PM
โMar-05-2018 08:50 AM
BurbMan wrote:Well, yeah it is according to Keystone who put it all together. They rate the axles at 6800 lbs. according to the labels, even though they are 7,000 lb. axles. Since the axles are rated by Keystone for 6800 lbs., I would say they are downrated from 7,000 lbs.
So if your tires are rated at 3400 lbs, then 3400 x 2 =6800 lbs. The axle is not "downrated", put on higher capacity tires if you want to carry the 7k it's rated for...
โMar-05-2018 06:26 AM
โMar-05-2018 06:17 AM
BurbMan wrote:That would only hold true if the tires are LT tires and not ST. "E" rated ST tires would be rated to 3400 lbs. My toyhauler came with "E" rated ST tires, and the axles were down rated to 6800 lbs. with a GVWR of 18,000 lbs.
It's the tires. A load range E tire has a rating of 3042 lbs @ 80 psi, so the axle is limited to 6084 lbs even though the axle itself is rated at 7k.
So 3 axles is a total of 18,252 plus whatever on the hitch/pin plus a safety margin for loading...side-to-side and front-to-rear, depending on how the rig is loaded will not distribute the load equally over all 6 tires, so if running at max weight it's likely that at least one tire overloaded and one is underloaded.
โMar-05-2018 06:16 AM
โMar-05-2018 04:16 AM
โMar-05-2018 03:33 AM
โMar-05-2018 03:09 AM
โMar-04-2018 09:35 PM
โMar-03-2018 01:52 PM
โMar-03-2018 12:15 PM
