3rd A/C Unit
BusaGuy
Wondering how hard it would be to get a third unit installed on the bunk end of my camper. Went to the beach this summer and it got HOT in the trailer.
2012 Dodge Ram 3500 DWR Cummins Powered
2014 Wild Wood Heritage Elite
DW, DD's, DS, and our 2 little dogs!!
22 REPLIES 22
R-D
Two a/c's are not enough for large 5th wheels in the summer heat (95 plus degrees)I also had mobile tech come and check the main a/c, he said it worked like it should. I installed a 3rd a/c in the rear vent of my 38ft fifth wheel. It did take some time pulling wires using a fish tape. But well worth the time and effort. I installed an a/c that was not ducted and find that it works much better. All the air goes dumps in the room with the a/c. On 50amp I can run all three. On 30amp I can run two, we always pick the 3rd one that dumps in the living area( I have a rear living plan). Good luck, you won't be disappointed with a 3rd air.
Old-Biscuit
40' 5vr......I'd change out bedroom one to a 15K
BusaGuy
I have had it checked and they ssay they are normal. The big one is ducted, but the small one is just for the master bedroom. I don't know what vto do.
azdryheat
Sea Six wrote:
How much would it cost to repair or replace the one (or two) obviously defective AC units you already own in that thar arrR. Vee?
You might read his sig - his trailer is a 2014.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
azdryheat
Are the two units you have ducted to each other? I have 3 a/c's on my Voltage and the middle (main) unit is fully ducted (there is no down vent) and the taping job where it joined the ducts was terrible. You might want to check your ducts for proper taping to make sure the cold air is going where it's supposed to go.
2019 RZR 1000XP TRE
robsouth
As Sea Six referred to..something ain't right with the two you have. Two units should have kept you cool even in the direct sun at the beach. You should have them checked out before you do anything else.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
lawrosa
yes two a/c's and not cool enough?? Wow...
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
Sea_Six
