4x4ord wrote:
justme wrote:
There is no easy answer, but if you pull a heavy load most of the time the lower gear is the better. Otherwise the high gear is prefer for light loads and intermittent heavy loads. Fuel mileage and engine wear (piston travel/mechanical stress) is important for long term wear and tear. For my experience the higher gears are preferred because I pull a heavy load intermittently. I pull a 165000GVW trailer with a F350 SRW with a 3.5 rear end. I have 40k miles on the trailer and 90K miles on the 2012 diesel truck. The TV pulls very well and if the tranny starts hunting between 5th an 6th gear, I lock it in 5th and everything is good. The torque on the F350 is fantastic and pulls grades very well. I see no need for 4:11 rear end.... I average 12mpg pulling 20mpg not pulling. I set the cruise control to 60 mph pulling and 75mph not pulling.
That is very good fuel economy. Do you have a programmer on it? I might see 20 mpg empty if the stars are all aligned and I don't exceed 60 mph. Pulling I'm more like 9 - 10 per US gallon. My overall average mileage for how I use the truck is 12.5 mpg.
No everything is stock. I traveled from California to the east coast and averaged 12.2 mpg for the entire trip. When I travel not pulling from Florida to Connecticut I get 20.1 mpg average for the whole trip. I use cruise control where possible and I use an additive to increase the Ctane rating of the diesel. The Ctane and quality of the fuel is noticeable. Most states mandate a Ctane of 40 while California mandates a Ctane of 50. So Californians should see a better mpg. If you use B20 you will see a significant decrease in mpg. If you use B5 in a good brand you will see an improvement. One time I had 23 mpg from fuel I bought on the NJ turnpike which is best mpg I have ever had. I wished I lived closer to that pump. Most of the truck stops are 40 while the do vary between 40 to 45 depending on the batch. Then of course environmental conditions and driving habits plan a big role :-)
If you use the power that your engine is capable of you will greatly decrease the economy. I some times wonder if the newer Fords that have increase their torque and H.P. would be more of a challenge to get better mpg than my 2012. That power increase may be nice but I could imagine that it will gabble up fuel much faster when one demands that power. My truck has all the power I need and I am happy with it, but I am jealous as well :-)
