50 Amp service is nice!
Arcamper
Siting at the lake last weekend and I notice the DW has the washer running, the dryer, the convection oven, fireplace with heat, two small space heaters, bunch of lights, tv, satellite, and the water heater and fridge are on electric. I start thinking about how much we are pulling and since the PI EMS 50 has the display it was easy. Wow, 44 amps on line 1 and 39 on line 2. When we had our other 5th wheel with 30 amp service we always had to watch what was running if she used her hair dryer and since we had a PI EMS 30 it was easy to do. I have seen questions on here before asking if 50 amp power is worth it as an option on some trailers and I can tell you it is. You really have 100 amps to use instead of 30 and that is a lot. I don't think we are ever going to have to count amps again.
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
14 REPLIES 14
HighSpeedAlumin
Old-Biscuit wrote:
mtofell1 wrote:
I love the things I learn on this board ๐Ÿ™‚ I always wondered how those big 5th wheels and diesel pushers could survive with 50A when I have run out on my TT with 30A.
The 30A is just @ 120V and the 50A is at 240V. So, like someone said - it's actually like 100A compared to 30A. So, are all the A/C systems and even clothes dryers on the big rigs just 120V? (on houses they are usually 240V which is why I'm asking).
30A.....1 hot leg, 1 neutral, 1 ground -------- 3600W Total
50A.....2 separate hot legs, 1 neutral, 1 ground ------- 12,000W Total (6000W per hot leg)
50A Main panel has 2 busses with 1 hot feeding each buss. Individual CBs feeding circuits and hopefully 'electrician' at factory balanced the loads
Thanks Biscuit You saved me writing that up. You have almost 4x as much power available with 50amp vs 30amp.
2015 Ram 3500 SRW Laramie Longhorn W/ Air Suspension.
2015 Grand Design Reflection 323BHS
buc1980
I like my 50amps I don't want to go back to 30.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
Cummins12V98
rhagfo wrote:
Irelands child wrote:
Our 5er has 50 amp service -- and we seldom use anywhere near that capacity with one a/c and no washer-dryer so generally just use the more easily handled 30 amp cable and a converter plug instead of dragging that ponderous wire and, often the equally cumbersome extension cord especially if we are only going to stay a couple days. Now, if I add the second a/c which is being considered, I might just have some surplus cable.
Not an issue if you have the right 50 amp cable (6/4 SO)! :B
This is our 40' cable stored in a 3 gal bucket.
HEY, nice cord. ๐Ÿ˜‰
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
RustyJC
There are a few items that are sometimes wired 240VAC in 50 amp rigs - that just means that they can't be used unless 50 amp service is available. Examples are the CheapHeat system in our Mobile Suites (the strip heat is wired across L1 and L2 for higher output), higher output electric clothes dryers, etc.
Some of the big Prevost-type high $$ rigs are all electric and take full advantage of 240VAC.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
Old-Biscuit
christopherglen
Yes, that way there is only one version of equipment (VS 120 & 240) and you can still use 30 or 15 amp if that is all that is available.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Learjet
yes 50 amp, or should I say 100 amps... and EMS ๐Ÿ™‚ can't go back...:)
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
mtofell1
rhagfo
Irelands_child
TXiceman
We have a 50 amp trailer and you sure get spoiled with not worrying about what to operate. We are currently at a park with only 30 amp service. Seems like we are in the stone ages. Before we turn on something else, we check the power panel to see how many amps we are drawing. WEll, up to 28 amps...now what do we turn off so that we can run the microwave, etc.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Golden_HVAC
Hi,
Back in 2004, Weekend Warior would install a 50 amp optional service in their 30 amp trailers at the dealership. It only takes about 4 hours once you have done a couple of them.
Basically they installed a 50 amp panel in a storage compartment, then ran a 30 amp breaker to the factory 30 amp pane, ran 20 amp breakers for the A/C units, and installed some 20 amp new receptacles in the garage area. It is pretty simple to install a 50 amp service in anything.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
CarlT100
I love my 50 amp service. I would hate to go back to 30 amp.
Carl S
US Army Retired
'11 F-450, 6.7, 4X4, crewcab; '14 Fuzion Impact toyhauler
'12 Triumph Tiger 800XC; '03 Triumph Bonneville T100, 1968 Triumph TR6 Trophy 650cc
SWMBO: '13 HD Sportster; '06 Honda Big Ruckus
wildtoad
We ordered our new Newmar with 30 amp service. Tried to get it upgraded to 50 but was told not available in the unit we wanted. One of the downsides of wanting a short motorhome I guess. Have used 30 amps for years and now we still will.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
