laknox wrote:
Old-Biscuit wrote:
As we start to pass another 5 er we see the cover on his dump pipe let loose and the sh...t starts to fly.
That statement implies this was NOT on purpose.....
Tank valve may have been left open by mistake OR did NOT fully close.
End cap popped off due to weight of stuff on line and bouncing from roadway.
I had a front axle tire driver side on 5vr BLOW.....took out common drain header and dump valves.
Hadn't dumped tanks that week....figured I would do it at next stop
Dumped/sprayed 120 gallons -------only reason to stop was due to blown tire. Not much I could do about tanks dumping.
And had a LEO stopped, he could also have ticketed you for illegal dumping, no matter the circumstances. Had that happen to a friend under similar circumstances. Went to court and got it tossed, though, and got to see the judge ream the LEO for wasting his time. Still, cost him time and court fees.
Lyle
LEO didn't BUT Kansas DOT did.
Brought me the ripped off header and helped me change tire using his big impact wrench.
Really wasn't concerned either way about LEO.
S**** happens and then you deal with it.
Just like life......What IFs will drive you nuts :B
