Adding 2nd awning on Voltage 3200 over rear entry door
Protector
Hello folks,
I am kicking myself for not doing this when we ordered our Voltage 3200, and now I want to add one, so I found retailer that sells the 10 foot awning for Keystonen and they contacted Keystone/ Dutchman customer service to see if in deed I could add the awning and I did not get a Yes or No they said this" I would advise against adding the awning unless you are sure there is proper backing behind the wall. This is the customers unit and this can be modified and added, but keep in mind that the project will no be simple because you will want to get visual confirmation of backing before securing an awning to it."
I am capable of installing the awning, getting power to it, what I am not sure of if there enough backing has anyone had any experience adding an awning??
I tried a stud finder looking for studs or some sort backing supports had no luck. Thinking about finding someone with thermal imager. any suggestions or advice
2011 Ford F-350 Crew cab, short bed King Ranch 6.7 Diesel
2012 Voltage 3200 TH
2010 Polaris RZR LE
12 REPLIES 12
Protector
Lightfoot, Thanks for the quick response!!
2010 Polaris RZR LE
Protector
MartyMoose wrote:
Hey Protector,
What is the name of the retailer and approx cost? I have been wanting to do the same so my Road Warrior.
What are you getting the power from?
Thanks!
Marty Moose,
I have no problem getting power in the back, there is entertainment system, and power for the happi jack bed system. I have some pictures of it, but I not up to speed on posting pics on here.
This is who Keystone told me to contact:
Tiara RV Sales & Service
Elkhart, Indiana 46514
866.880.3093
Awning - Hardware - Adjustable Pitch - Black - Standard - Single Set $693.34/set
Awning - 10' - Single Side - Black/Gray - Travel'r Electric $236.90/ea.
www.tiararvsales.com
2010 Polaris RZR LE
lightfoot
There is 7" C2C between the 2 on the right and 95.5 C2C for the awning.
USN EN2
2012 Ford F250 SC, 6.7L TD
2015 Voltage 3200
2004 Honda GL1800 Reverse Trike
Protector
Great picture, If I could ask,could you get a measurement center to center on of the rails? I should be okay with structural support towards the rear, As I have the Happi jack bed rail on the backside and should be a good point of attachment and is in the same area as the as your left support arm. I am just not sure about finding any support between the door jamb and the other awning support on the right side?
Thanks in advance!!
2010 Polaris RZR LE
lightfoot
I have a 2015 3200 with the 2 awnings on the side and the one in the back. Here is a picture of the one on the side. Hope it helps you get an idea where the arms would be located.
USN EN2
2015 Voltage 3200
1jeep
im considering the same thing on my carbon, it appears it has every option but the rear awning. I have even considered installing a non electric unit over the rear door, but don't know if ill like having arms bolted to the side.
2016 Ford F350 crew cab dually 6.7 platinum with heavy tow and 4:30 gears
2015 Carbon 327 with a BMW k1600 and Canam 1k inside
MartyMoose
Hey Protector,
Thanks!
2014 Heartland 305RW Road Warrior
2012 Ford F250 Lariat
mr__old_style
I ran bolts all the way through the wall and had a piece of aluminum plate on the inside, painted to match the interior walls.
Protector
Good point Joe.
2010 Polaris RZR LE
joebedford
Nomad II
Nomad II
I've found on a damp morning before the sun gets on the side of the RV, the outline of the studs is clearly visible.
Protector
Yes side entry door, That was my thought finding someone with a thermal imaging camera. You would think that the mfg. could look at some drawings and tell you yes or no there is structural support but I guess it is not that simple??
2010 Polaris RZR LE
Wild_Card
Your talking side entry door not rear ramp door right.
My thought is the structure should be there if it was a factory option. They only build 1 wall. They dont build a wall for the awning and a wall without the awning. Findin what structural memebers are in the area needed are easy via thermal imaging or even condensation in cool mornings.
The bugger is the electrical
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
