Hi, For those of you with air bags on the rear axle and a fifth wheel, how much pressure do you use? I started with 30 PSI and now increased to 38 PSI. About 2,750# of pin weight. Crespro
I added air bags to a 2500HD when I got a lance camper. The specs say it was 2500 pounds so I would put 50 psi in them. I seem to remember the spec sheet said 1 psi for every 50 pounds. Now I have a small TT and I use 20 to keep it level. I quit using the load leveler bars as they are a pain. No problems so far and it has worked for 10 years.
