AIRBAGS WITH B&W COMPANION HITCH ADVICE?!
rockwind1
i looked into airbags many years ago 2001 f350 and ran into an obstacle with my b%w hitch,, as many know,, it is an under the bed platform that bolts into the frame and then the fifth wheel hitch attaches to it via a unique method. the problem is that all the airbags i looked at would not go in as easily as they would without.
question: has anyone found airbags that would go in without major mods with the b&w?
if not,, has anyone found a fairly easy way to do the mods? would you share?
thanks
10 REPLIES 10
rockwind1
mtofell1 wrote:
I have Firestone 5000 bags with a B/W Companion on a 6.5' bed 2500 2014 Ram with no problem. The hitch went in first and then I had the bags installed. They guy that installed them didn't say anything about any problems. I can't recall ever really looking at how close they are but I could snap some pictures if you need them.
thanks! i appreciate it,, prob not necessary,,,, i am going to buy airbags soon and install. i am starting another thread with a related question
fishhogg
2017 F350 SRW 4WD Long Bed W/ factory puck system. Firestone air/bags and Air Lift WirelessAir Compressor. Great system with no problems and B&W 20k Companion hitch.
mtofell1
rockwind1
garyp4951 wrote:
2001 F350 air bags
hi gary,, thanks for the link,,, did that airbag set up work with the older b&w companion hitch?
garyp4951
Fulltimer50
I have a 2011 F350 DRW 4x4. I had no problem installing my Ride Right air bags.
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
rockwind1
gwalter wrote:
I have airbags on my Ram with the B & W Companion hitch.
really? would sure like to talk to you sometime then,,, maybe a ram is different than my f350. the bags went in no problem? no welding or cutting?
gwalter
2010 Ram 3500 Laramie
2021 Bighorn 3120 RK
B & W Companion Hitch
Air Bags
rockwind1
dmck413 wrote:
I used Timbrens on my Dodge. They went in easily and perform very well. Made the truck stiffer riding though.
do you have the companion hitch?
dmck413
