Jun-21-2017 01:50 PM
Jun-24-2017 05:08 PM
Me Again wrote:ralphnjoann wrote:
Well, for one thing, the Andersen hitch does not cause "100 percent" of the weight of the trailer to be carried by the bed of the truck.
Second, the pin weight is carried by a ball mounted on a cross member secured to the rails of the truck. Snugging down the hitch so it doesn't shift does not place pin weight on the bed. That 40 or so pounds of force is there whether or not a trailer is attached.
Finally, the problems you had with your pin box must not be widespread since yours was the first and only one I have read about on these forums.
You can not pull down and hold up with the same mechanism.
Jun-24-2017 04:18 PM
Jun-24-2017 04:10 PM
Jun-24-2017 03:56 PM
Searching_Ut wrote:SabreCanuck wrote:
Honestly, I haven't been on this forum for 6 months and the first thing that comes up is you guys and this Anderson topic again. Crazy.
Please also keep in mind that every time you talk about the Anderson, everyone always seems to forget there is a RAIL version that has nothing to do with a gooseneck ball which at the same time means that just cause it's an Anderson doesn't mean the weight is on the ball, box, bed, etc. The weight is spread just the same as any other hitch on the rail version.
Indeed, there is a rail version, but it only comes in steel, with very little weight advantage over several rail mounted conventional hitches. Myself I find the conventional hitch head far easier to hitch and use than I did my Andersen. The advantage was in weight, which with my B&W puck mount is admittedly significant. That said, it hitches much easier, especially when the trailer and truck are tilted significantly. The ball hitch would sometimes hang up both disconnecting and connecting.
Back to the original question of failure, when I think about it, approximately a third of the fifth wheel crashes I've come across had the hitch fail in the crash. Saw one a few weeks ago on I-80 across the salt flats with 5er on side, truck upright and separate. News said wind blew it over and hitch decoupled. Hitch type unknown. Another on I-15 where truck had gone into center median, jackknifed and tipped over and was upside down with upright 5er having been pushing it through dirt. Another fatal on a local road where RV T-boned a car, fatal for car occupants, 5er stayed coupled but caved in back of truck in tailgate area and back of cab. Truck occupants walked away though. These are just ones I've personally seen in the last year which begs the question, how often do fifth wheel hitches of any type fail during accidents?
Jun-24-2017 02:31 PM
Jun-24-2017 02:14 PM
Searching_Ut wrote:Well, for one thing, the Andersen hitch does not cause "100 percent" of the weight of the trailer to be carried by the bed of the truck.
For those unfamiliar with the Andersen Ultimate hitch, 100 percent of the weight of the trailer is carried by the bed of the truck, and none is carried on the ball in the bed of the truck. The truck bed ball is used as an anchor point with a pin that goes under the ball to anchor the hitch. You then tighten a bolt on on top of the tube that pulls a tub within the tube to pre-load the the base tightly against the bed of the truck. The truck bed ball is used for pulling to pull the hitch down, not to support the weight.
The other thing to keep in mind is that all of the pin weight for the trailer is transferred to the two set screws on the pin adapter between the ball and pin. The pin box not being designed to support the weight in a small area rather than distributed across the pin box base plate is what resulted in damage to my bighorn.
Jun-24-2017 01:47 PM
Jun-24-2017 01:03 PM
fj12ryder wrote:
I don't know that you could call this a "catastrophic failure". If your trailer comes apart in a crash is that a "catastrophic failure", or the results of the crash? If the frame of your truck deforms after hitting a tree at 70 mph is that a "catastrophic failure" or the results of hitting a tree at 70 mph?
Personally I think the B&W hitch deformed when subjected to extreme forces in a rollover crash. I don't know that subjecting something to forces way beyond its design parameters should lead to surprise when there are problems. If you drive a 20 ton load over a bride rated for 5 tons you shouldn't be surprised when it collapses.
Yeah, I love my B&W hitch. 🙂
Jun-24-2017 12:02 PM
fj12ryder wrote:
"President, B&W HeavyWeight FanBoy Club" 🙂
Jun-24-2017 09:20 AM
Jun-24-2017 08:45 AM
Jun-24-2017 08:17 AM
Jun-23-2017 03:53 PM
Cummins12V98 wrote:
IdaD, yes we can disagree and be civil! Seems the part of my OPINION of how they are a quality US manufacturer gets lost in the dust.
Jun-23-2017 03:39 PM
laknox wrote:Thanks for posting that, now I don't feel so foolish, or not quite anyway. I did the same thing by pinning the turnover ball in the wrong hole. I noticed some clunking noises and checked everything out and discovered my error. Like you, no damage, not even any dents in the bed from the base rocking. Just the SMH moment.
Also, from personal experience, very early on, I "high-hitched" my entire Companion in the base and didn't realize it was not firmly down against the bed, by about 1". Hell, I even torqued the entire thing! I hitched up my FW and towed it from storage to my house, about 12 miles. Felt a little different, but it handled just fine, and without any damage, whatsoever. Scared the bejesus out of me when I realized what I'd done, though! :E
Lyle
Jun-23-2017 02:12 PM
fj12ryder wrote:
I would imagine the "alt physics" are the same ones that work with a direct gooseneck hitch. The load is supported by the gooseneck ball which is bolted to the Companion base. Pretty easy to understand. The bed will probably deform some as the weight is applied, but only until the weight is supported by the turnover ball, then the weight is supported by the gooseneck/turnover ball structure under the bed, that is bolted to the frame.
