Jun-21-2017 01:50 PM
Jun-23-2017 02:11 PM
Me Again wrote:laknox wrote:Cummins12V98 wrote:
^^^^^ Correct the PUCK Companion attaches to the pucks that directly attach to the frame. The regular Companion attaches to a post that attaches to a Gooseneck hitch mounted under the bed.
To further clarify, the GN base takes virtually all of the vertical load on the hitch; the base =stabilizes= the unavoidable fore/aft flex in the hitch system. I can only assume that the puck system transfers the load directly to the frame =and= stabilizes the fore/aft forces at the same time. Haven't yet seen one in person.
Lyle
Lyle please explain the alt physics that allow the GN base to takes any direct load. With the bed between the base and the hitch base the load is on the bed floor. With the addition of the strips to fit in the bed valley things improved. however the GN base is only under the very center area front to back and the hitch base extends both ahead and behind the GN base. Rather than Companion, it should be named Compromise.
Jun-23-2017 01:21 PM
Jun-23-2017 01:09 PM
Lyle
Jun-23-2017 12:21 PM
Jun-22-2017 09:58 PM
Jun-22-2017 04:28 PM
Cummins12V98 wrote:
There is a reason Andersen re designed the aluminum Ultimate.
Personally I feel Anderson makes a quality US Made product. BUT, IMHO their ratings are way too high. For one they can and will deform the bed since the base is just using the bed to keep it stable. Hard braking or accelerating with a heavy RV will cause this problem. The old B&W Companion did the same thing (i know from personal experience) until they re designed it so the base placed its pressure points to the low part of the bed corrugation and to the bed cross rails.
I would consider an Andersen for the 250/2500 market but none higher. Oh, BTW the "crush test" video is a bit of a joke. How about a real world fore aft test???????
Jun-22-2017 04:00 PM
Jun-22-2017 03:24 PM
ralphnjoann wrote:TenOC wrote:JIMNLIN wrote:
Never heard of anyone wanting a trailer (any trailer) to come loose in a wreck. Having logged over 1.2 million miles pulling trailers (non rv) I sure wouldn't want one coming loose....any time.
Per the link above and repeated here Wreck with 5er. Hitch failed Photo near the botton.
"If the truck had rolled over too, Mark and Doran could have easily been very badly injured or even killed. However, because the truck stayed upright, they walked away unscathed. Thank heavens!!"
That's a bit of speculation. They could have been killed or badly injured if the upright truck had careened into oncoming traffic.
Jun-22-2017 02:02 PM
Jun-22-2017 08:39 AM
Jun-22-2017 07:28 AM
WTP-GC wrote:
one should expect failure of this product...just like one should expect failure of any man-made device. There will always be the chance that a weld was done improperly or a material defect exists beyond the manufactuer's control. But The overall number of failed UH's is minuscule. I can count only one time where pictures have been posted of this, plus 3 or 4 other written claims. All things considered, that's not even enough to raise an eyebrow at.
This entire forum seems to be a dedicated place for RV owners to come vent or rant about one problem or another with their rig. Blowouts, water damage, delam, reefer issues, water heater issues, etc. etc. etc. The Andersen UH doesn't even rank on the list of common complaints from actual users.
Jun-22-2017 07:15 AM
Jun-22-2017 07:14 AM
ralphnjoann wrote:I don't know that you could call this a "catastrophic failure". If your trailer comes apart in a crash is that a "catastrophic failure", or the results of the crash? If the frame of your truck deforms after hitting a tree at 70 mph is that a "catastrophic failure" or the results of hitting a tree at 70 mph?WTP-GC wrote:
I agree 100%. The B&W Companion, for example, is a highly regarded hitch on these forums and I wouldn't hesitate to buy one if it met my needs. But here is a LINK to a report showing a catastrophic failure of the hitch when the trailer overturned. Would this single example be a reason not to buy the hitch? Not for me - stuff happens.
Jun-22-2017 06:39 AM
Jun-22-2017 05:59 AM
