I also called Andersen and got the exact opposite description than DAVISENVY. The Head of Sales said the weight is distributed over the entire andersen frame, and not directly on the truck gooseball. The attachment to the truck gooseball is with bolts going under the ball circumference and tightened to pull UP on the ball securing the Andersen frame tightly to the truck bed, serving the purpose of puck attachments that do the same job. No weight is placed directly ON the truck gooseball, in fact it is negative weight.
So the question remains where does this hitch platform place the center of that weight distribution in relation to the truck axle. To determine this I located the schematics for their steel and aluminum versions of the Ultimate hitch, attached below. Considering the aluminum one as my desired hitch, it shows a 31.5" platform length from front to rear. Half of that for the center would be 15.75", which would be 1.75" rear of the gooseneck ball center line looking at the aluminum version measurements.
Now the question is where is the truck's gooseball in relation to the rear axle. On my existing 2011 Chevy long bed dually, it appears to be about about 6" in front of the axle.
So the center weight would be 1.75" back of that, or about 4.25" in front of the axle - looking good!
To confirm a bit further, I looked up the installation instructions for B&W Companion hitch that was installed on this current Chevy, and it shows a 49.5" distance from rear of long bed to center line for gooseneck ball hole (44.75" for short bed). I measured 49.5" from rear of my bed and it aligns perfectly with the ball.
Now my next questions are 1) does the 2017 Chevy short bed factory gooseneck do a similar "set forward" for the ball over the axle; and 2) if the aluminum version distributes weight over the pads on the truck bed and not on a support structure, but the steel rail version does attach to pucks directly on a support structure, it would seem the steel rail version would be much firmer, right?
Steel Ultimate (not rail):
Andersen Steel Ultimate measurementsAluminum Ultimate:
Andersen aluminum ultimate measurements
