Lwiddis
Dec 26, 2018Explorer II
"2 more T105 batts for a total of 4 of the T105."
Your four T105 have a total of 450 12 volt AHs. The general rule is one solar watt per amp hour, so you'll need 450 solar watts minimum. If you have lots of shade or a mountain cuts off some charging time, get 600. As Don said you should be able to forget the generator. Be careful mixing solar panels. Same type and watts is safest.
"Firman P08003 8000 watt generator"
Its not what you can "throw" at your batteries but what will they accept during charging.
About Fifth Wheel Group
19,019 PostsLatest Activity: Jul 02, 2025
